05-18-2012 07:44 AM - edited 03-16-2019 11:14 AM
Hi everyone,
I'm trying to set up a sip connection between ITSP and my company. When I got incoming calls from PSTN to my online number this is showing a alphanumeric called number instead numeric as below:
May 18 14:33:29.248: //11085/45231A6AA411/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x485ED634
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 2721048092
Called Number : companyname01
Source IP Address (Sig ): 10.21.18.100
Destn SIP Req Addr:Port : 201.86.87.2:5060
Destn SIP Resp Addr:Port : 201.86.87.2:5060
Destination Name : 201.86.87.2
May 18 14:33:29.248: //11085/45231A6AA411/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : g729r8
Negotiated Codec Bytes : 20
Nego. Codec payload : 18 (tx), 18 (rx)
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Address (Media): 10.21.18.100
Source IP Port (Media): 18952
Destn IP Address (Media): 201.86.87.2
Destn IP Port (Media): 13506
Orig Destn IP Address:Port (Media): [ - ]:0
May 18 14:33:29.252: //11085/45231A6AA411/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC) : 16
Disconnect Cause (SIP) : 500
Question is, how I will route this call once the called number is alphanumeric?
Anyone else already fixed that?
Thank you and I really appreciate any help
05-18-2012 08:09 AM
I believe you can do URI based routing on your dial peers. Make sure you define the URI.
05-18-2012 08:23 AM
How I can do that?
05-18-2012 08:51 AM
05-19-2012 09:29 AM
You need to ask you ITSP to send a called number.
