Is there a way to add the external phone number mask specific for the remote destination profiles?
Look at the attached screenshot.
If you select your remote destination profile in the controlled devices list and click "edit line appearance", then you are able to fill in some RDP specific parameters on line level such as display text, ASCII text label and external phone number mask.
I would like to modify the phone number mask for a bunch of RDP profiles... but can not see where i can do that via the Bulk Administration tool.
Anyone who has experienced this?
In worst case, we need to modify this manually... but i hope not
Thanks for your feedback,
Kurt De Neef
