11-19-2018 01:23 PM - edited 03-17-2019 01:44 PM
I wanted to modify the background image of IP phone. I have uploaded the updated image to CUCM server successfully.
My question is on last step below - Is there any other way that I, as administrator, could change the options of background images without any user's involvement? I mean the users doesn't need to manually change anything on their end.
"On the IP Phone, go to Settings > User Preferences > Background Images, and choose the thumbnail that you want to apply. They should be there now"
Currently there are 3 options of background images. Most of phones are option 2 & 3. I have uploaded two images files with exact same file name to CUCM, which are option 2 and 3). The tested phone, is still showing old image option 2 after I restarted TFTP service. I still have to manually go to phone settings and pick the option 2, and then the phone shows updated background image.
I heard there are 3 parties applications.... just wonder if any other method to make this happen. Your input and thought are appreciated.
Best regards,
Master001
11-19-2018 01:57 PM
I havent tried (yet) but I would suggest to modify your Common Phone Profile Configuration, then add the new image to the Background Image field in the format mylogo.png.
If you don't want the user selecting their own wallpaper, then uncheck Enable End User Access to Phone Background Image Setting. Save and apply the phone profile. Restart the phones so your changes take effect.
G
Please rate, if useful
11-19-2018 09:30 PM
11-19-2018 09:37 PM
We (CommSouth) are a 3rd party solution provider on top of Cisco Products. As per the other posts shared by our friends, you can try to do the task manually with the steps detailed in the link shared to you.
Apart, if you are looking to simply this process, we do have a solution for Back ground image changer. If you are interested, please contact me at prasana@commsouth.com
Prasana Kumar. P
CommSouth
Head - Business Solutions
+91-9841027006
12-27-2018 11:04 PM
