04-02-2013 01:43 PM - edited 03-16-2019 04:34 PM
Hi Everyone,
I am trying to remove the Moh from the conference calls but don't seem to be able to manage those calls coming into the meeting from Lync. Does Lync looks at the MRGL/DP configured in the Client Service Framework for the Moh?
MK
04-02-2013 02:42 PM
Is this CUCI-Lync since you mention CSF, or is the Lync participant calling into the CUCM conference across SIP trunk?
Chris
04-02-2013 03:12 PM
Its CUCI-Lync and also Lync participant calling into the CUCM confernece using SIP trunk.
MK
04-02-2013 07:19 PM
Any idea Chris?
04-03-2013 06:21 AM
Who is starting the conference bridge and who is hearing the MOH? I am assuming this is ad-hoc CUCM conference bridge which by default suppresses MOH to all participants, you can check that by looking at the service parameter:
"Suppress MOH to Conference Bridge Required Field" which should be set to True.
HTH,
Chris
04-03-2013 07:37 AM
The CFB is in the CUCM and some remote people use their Lync to call into CF. The "Suppress MOH To Confernece Bridge" is set to true but we hear Moh from those Lync phones when they put the meeting on hold. My question is how the SIP trunk deals with Moh. Does it look at the MRGL configured for the CSF or it looks at the CUCM service parameters filed "Default Network/User hold MOH Audio Source ID"?
MK
04-03-2013 08:00 AM
Well this is expected as Lync is an external system, this is no different from if you called in from PSTN and the system you are on is configured to provide MOH. The MOH is coming from Lync side not CUCM.
HTH,
Chris
04-03-2013 09:55 AM
Chris, the follwoing is the call flow:
Cisco Phone <----> CUCM SIP Trunk <-----> CUBE <-----> Lynce Media Server.
In this case, is the Moh coming from Lync Media Server?
MK
04-03-2013 09:57 AM
If it is the Lync user pressing HOLD button then yes. MOH source file always originated from the person initiating hold.
HTH,
Chris
04-03-2013 10:03 AM
