02-04-2020 08:21 AM
Hi folks!
Faced following problem:
- after configuring MOH on CUCM server (did same configuration on both nodes) I tried to put caller on hold. On other end of line there is no music on hold played.
Configured MOH in this way:
1. Media Resources -> MOH Audio File Management -> uploaded file
2. Media Resources -> Music on Hold Audio Source -> added new moh source with next stream number
3. Media Resources -> Music on Hold Server -> already have activated IP Voice Media Streaming service in CU Serviceadbility, so just checked server parameters and set same Device Pool and Location values as for devices
4. Have selected MOH audio source for both device and line
Any try to restart, reconfigure and tune MOH servers - unsuccessfuly.
Did you have same sort of problem or at least you have an idea about how to fix MOH service?
Thanks in advance!
Solved! Go to Solution.
02-04-2020 08:27 PM
02-04-2020 08:31 AM
02-04-2020 08:27 PM
02-10-2020 07:04 AM
Success!
Found both misconfuguration:
- MRGLs were different with different MOH assigned
- issue with audio file properties
For me that seems strange, isn't CUCM should just convert audio file to the proper format during upload process and being able to use it for MOH?
02-10-2020 11:48 AM
not necessary. You need to make sure that audio coding is correct (frequency, sampling, etc) for CUCM to convert it to the required codecs successfully.
**** please remember to rate useful posts
