MOH for CME 10.5
AT
Is 8K Hz the only rate supported for  CME 10.5 MOH?  I have a custom MOH file at 48000K Hz and after a conversion using audacity it is not usable.
AT
Hi At,
For CME all i can find is below
music-on-hold filename containing G.711 A-law or u-law 8KHz encoded audio file (.wav or .au format). The file must be loaded into the routers flash memory, e.g., flash:/moh.au or flash:/audio/moh.au The minimum supported file size is 100 Kb.
Nothing for  48Khz on CME.
I can confirm that the below is for CUCM
This  format mentioned:
•16-bit PCM wav file
•Stereo or mono
•Sample rates of 48 kHz, 32 kHz, 16 kHz, or 8 kHz
(Rate if it helps)
JB
5 Replies 5
Jitender Bhandari
Hi AT,
See below for help
https://supportforums.cisco.com/document/133211/configuring-custom-media-files-music-hold
https://voiceonbits.com/2010/06/29/moh-issues-and-resolution/
JB
Thank you for the info.  The two docs kind of contradict each other.  My application is CME not CUCM.
•Stereo or mono
The voice-bits says only 8K Hz audio ?
Will CME be able to use 48Khz ?
AT
Hi At,
•Stereo or mono
(Rate if it helps)
JB
Thank You !
Hi AT,
I also find below for you, it for UC520 running CME, but there is not much difference other than capacity.
https://sbkb.cisco.com/CiscoSB/GetArticle.aspx?docid=f09fd24f2b13491d96c2f314a1806a6e_Music_on_Hold_MoH__file_Standard_Format_Conversion.xml&pid=2&converted=0
(Rate if it helps)
JB
