MOH Issue
V.Naveen Kumar
HI all,
I am facing issue in moh..!!
we have two sites site 1 and site 2
1:with in site 1 moh is working fine
2:with in site 2 moh is working fine
3:when caller put on hold in site 2, then we (site 1) can hear it.
4:when caller put on hold in site 1, then we (site 2) cannot hear it.=====> ISSUE
we are using CUBE to connect these two sites.
help..!!
Chris Deren
What system? CUCM, CME?
Why do you have CUBE between sites?
Are you using unicast or multicast MOH?
Chris
Its in CUCM and its two cluster not site.
we are Multicast MOH..
May I ask why you have CUBE between 2 clusters?
is there proper MRGL assigned to either the Device Pool or SIP trunk on cluster 2?
Since you stated you are using multicast, are you using different multicast addresses on each cluster?
Chris
this is setup
CUCM 1-->SIP T-->CUBE-->SP-->CUBE-->SIP T-->CUCM 2
whenever the person from cucm 1 put on hold and the person from other end not able hear music getting silence.
insite cucm 1 moh is working fine..
i have enable multicast moh in cucm and i have configure multicast moh in cube
but still it is not working..!!
