MOH not playing at beginning
xandershimmin1
I have an issue with Music on Hold not playing from the beginning, It's only for any extra calls, The first call will hear the beginning but any calls after don't? I don't have multicast enabled anywhere yet it still doesn't seem to create different streams per call. Why is this?
I am running CUCM 8.6.
Alex.
During active moh, issue this command on the node where moh server is registered. Please share the output
show perf query class "Cisco MOH Device"
Ok this is strange, I got this when 2 calls were on hold even though both played at the same time as if it was multicast
- Perf class (Cisco MOH Device) has instances and values:
MOH_2 -> MOHHighestActiveResources = 2
MOH_2 -> MOHMulticastResourceActive = 0
MOH_2 -> MOHMulticastResourceAvailable = 250000
MOH_2 -> MOHOutOfResources = 0
MOH_2 -> MOHTotalMulticastResources = 250000
MOH_2 -> MOHTotalUnicastResources = 250
MOH_2 -> MOHUnicastResourceActive = 2
MOH_2 -> MOHUnicastResourceAvailable = 248
Do you have any suggestions or info about this?
Cheers.
It seems like this must be a standard behavior for cucm 8.6?
