429
sandeepontop
Beginner
MOH not working.... Help required.
MOH is not working when I place a call on hold and also during transfers. Checked in the Media Resources and the config seems to be working fine. Is there anywhere that I need to check apart from Media Resources. I have a Call Manager 6.1(2) system.
1 ACCEPTED SOLUTION
Also if you have configured MoH to use multicast make sure the network is set up to support multicast traffic.
Also check your MRG's and MRGL's.
3 REPLIES 3
What is the call flow ? internal to pstn ? site to site ? MOH server's are registered ?
Do you hear a fast beep or deadly silence?
Never work or suddenly stopped working?
Guilherme Henrique Villarinho www.avvid.net
Thanks guys for the info.. I restarted the MOH Servers and the issue was resolved. Restarting did the trick. Once again thanks for your timely help !!!
Create
Recognize Your Peers
Content for Community-Ad
