09-12-2013 08:50 AM - edited 03-16-2019 07:20 PM
I wanted to find out how others are deploying MOH for CUCM servers that are vitual. We have an 8.6.2 CUCM cluster that currently has a DMX Fusion Player connected via a USB dongle. Planning on virtualizing this server and wanted to know what options there are for physical music on hold sources. Or what others are doing and how you have been able to make it work. Thanks.
Solved! Go to Solution.
09-12-2013 09:42 AM
Read this:
Short answer, you don't integrate the ISR, you just use the same IP you configure on the ISR, in your CUCM config and instruct phones to listen to that stream.
You just mix the above config with the CME config for a live feed audio source to do what you want.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
09-12-2013 08:55 AM
You have 3 options:
1. do not use hardware MOH, switch to .wav files
2. Deploy MCS server for it
3. Use E&M connection on a router
HTH,
Chris
09-12-2013 09:11 AM
Thanks for the quick response.
Would Multi-cast MOH be an option? I've been reviewing that configuration, but seeing as how it doesn't work with CTI devices, wasn't sure how that would impact Contact Center integrations.
If I used an E&M port on a router, would the device have to be controlled via MGCP by call manager? Would that E&M resource be registered as an Audio Source?
Have you found advantages for E&M over .wav files?
Thanks.
09-12-2013 09:13 AM
You would use the SRST as MOH source config, just don't use a wav file, but the E&M port to input the audio
java
09-12-2013 09:26 AM
Sure, but multicast vs. unicast has not bearing on your question which was about MOH source rather than delivery. You can deliver any source (.wav or hardware) via unicast or multicast.
HTH,
Chris
09-12-2013 09:35 AM
Thank Jamie and Chris.
I see what your saying Chris. Even if I had a wav file, I could use multi-cast or unicast.
If I were to use an E&M port on a router and connect our existing DMX Fusion player up, how would this register to CUCM so that I can add it to our MRG's as I have today with our directly connected hardware? Would there be any functional changes be leveraging the DMX player through an E&M port vs a direct connect to the CUCM MOH server?
09-12-2013 09:42 AM
Read this:
java
01-13-2014 11:28 AM
Hi Randy,
Would you mind sharing what you ended up doing on this? I have a similar situation: I need to stream a MOH source to a virtualized CUCM environment on a non multicast-enabled network (due to contact center, as well). Documentation that I've found seems to indicate multicast is required to do this. Any input you may have would be appreciated.
Thanks!
01-13-2014 11:31 AM
We just left everything on MCS servers. We would have moved to loading files on the server and virtualize it, however we did not want the music on hold to always start over when placing a user on/off hold, needed to have a continuos stream. No choice but to leverage an existing MCS server so we left it physical.
01-14-2014 11:18 AM
Thanks for the quick reply. I noticed in the release notes for Version 10 that MCS will no longer be supported for CUCM, so I was looking for an alternate means of deploying a live feed. Hoping something will come about - kind of inconvenient to not be able to stream.
