09-20-2012 07:05 AM - edited 03-16-2019 01:18 PM
I would like to know if it's posible to have a MOH server ( windows or linux ) that will have an application to feed a CUCM in unicast for the MOH.
note :
0 ) I can't upload prompt because they daily change based on a marketing department.
1 ) I dont want a multicast diffusion because I want UCCX MOH and it use CTI... and cti port doesnt support multicast.
2 ) I cannot use a E&M card on a gateway router connected to the MOH server because the config in the gateway is only in multicast
anyone ?
09-20-2012 07:22 AM
Assuming you have MCS servers, all you need is the MOH USB adaptor so you can have a live feed.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
09-20-2012 07:26 AM
Actually, I have a standalone serveur that carry some wav file.
Wav file are daily changed by a marketing department ( ...thats why wav file cannot be on cucm )
I am asking me if I can install an application on it to feed a the CUCM server.
From CUCM server I will have the standalone server as the MOH source.
Is there any application that I cann install to create a MOH unicast feed to CUCM.
