Monitor FXO port PSTN line button CUCM.
Marwan Urabi
is there any way to make special button at phone to monitor PSTN FXO line under CUCM 11.X
same as CME configuration .
dial-peer voice 8000 pots
 description ** Land Line 1 **
 destination-pattern 9000
 direct-inward-dial
 port 0/0/0
 forward-digits all
 no sip-register
ephone-dn  100  dual-line
 ring internal primary
 number 800
 label Land Line 1
 no huntstop
 trunk 9000 transfer-timeout 40 monitor-port 0/0/0
HARIS_HUSSAIN
We can monitor the Trunk utilization in RTMT, but I think CUCM doesn't have such functionality yet.
Please rate and mark correct posts<<
Frankly it's strange if this not available at CUCM !!
This reply might look very late but just wanted to participate as I had a similar scenario on cucm 11.
in my case I have used a deducted extension that the FXO port are forwarded to it using the h323 connection plar opx xxxx, and using subscription enabled with appropriate calling search space, you will now have the ability to check the FXO port availability such as any extension, and you can have this extension shared line.
If you reached to a better solution, kindly share with me yours :)
