753
Highlighted
Beginner
Beginner
Monitor FXO ports with RTMT
Is there a way to monitor a specific group of FXO ports on a gateway and configure RTMT to send out an alert if all of those ports are in use?  I have found some a couple of posts hinting that it should be possible but I'm not sure how to set it up in RTMT.  I've been trying to set it up by going under Performance, Cisco MGCP FXO Device and PortStatus but that doesn't seem right.  Any suggestions would be helpful.
1 ACCEPTED SOLUTION
Highlighted
Rising star
You can configure alerts to send you an email when they are seen. Below is a link for the RTMT Admin Guide for 8.5.1 (I don't know what version of CUCM you have but this should be fine)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/8_5_1/rtmt/RTMT.html
Yosh
HTH Regards, Yosh
2 REPLIES 2
Highlighted
Rising star
Yosh
HTH Regards, Yosh
Highlighted
Beginner
Beginner
After reading through the guide I figured out a way to get the information I want.
