11-23-2006 11:28 PM - edited 03-14-2019 06:57 PM
Currently we use Whatsup Pro to monitor our network. Can you make WMI call to CCM and Unity? If so what kid of information can you get and how?
Also what type of applications do you use to monitor your CCM.
Raj
11-24-2006 07:49 AM
Hi Raj,
Cheapest option is RTMT which is included in CCM. Can install the client from the plug ins page. It lets you set thresholds on counters, and send out email alerts if they are breached. Seems to do most of the stuff to keep your system running. Doesnt help you with management sort of reports and stuff though.
There are a couple of cisco options also.
Or these guys www.prognosis.com
Cheers,
Tim.
11-24-2006 01:52 PM
Thanks Tim.
I have installed RTMT but it does hold history and only good for real time stuff.
I will check out prognosis. I also checked and looked into Nimsoft
Thanks Again.
Raj
