Monitoring (Listening) to active calls.
dpaquet
Is there a way to monitor (listen) in on active non-agent calls?  The customer will be using a combination of Cisco 78XX, 88XX and Jabber devices and wants the ability for managers to actively listen in to on-going calls.  These are non-contact devices so silent monitor won't work unless Cisco has included SM in the CUCM application.  Is there a 3rd party application that would work?
David Paquet
5 Replies 5
PTS
Hi David,
Your requirement of monitoring non UCCX/UCCE agent call can be fulfilled by the 3rd party solution Parsec's "MARS Silent Monitoring"
http://www.parsec-tech.com/parsecapplications.html
HARIS_HUSSAIN
Close to it is the barge and Cbarege Features. You can setup Supervisor with shared lines . It works with shared lines
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
CommSouth
Hi David,
Yes, it is possible for CUCM users to do the Call Barging. We do offer such 3rd Party solutions. Please refer this attachment.
Prasana Kumar
CommSouth
Prasana Kumar.P
CommSouth,
Head - Business Solution
+91-9841027006
PTS
Have your monitoring requirement been fulfilled
PTS
Has your monitoring requirement been fulfilled.
If you are open to 3rd party solutions please check out MARS Silent Monitor Whisper application for Cisco CUCM
Please refer attached document.
For more details you can write to info@parsec-tech.com
www.parsec-tech.com
