04-09-2009 10:55 AM - edited 03-15-2019 05:24 PM
We are looking to monitor pstn trunk utilization from the Cisco Call manager 5.1.Can someone please recommed a MIB that specifically gives us this information.
04-09-2009 03:09 PM
not sure about the MIB.
you can use RTMT to monitor active calls, completed calls and so forth on any gateway from RTMT, you can also set up a preformance instance to write the data to CSV file
04-11-2009 09:41 AM
You can use the Real Time Monitoring Tool. Since this is a MGCP gateway all of that information will be available through CDRs and other CUCM-based monitoring.
hth,
nick
