12-28-2010 11:25 AM - edited 03-16-2019 02:37 AM
Does anyone know of a product that can graph PRI usage such as Active Calls or dropped calls... either from a Router or from Call Manager (7.2)? I have CactiEZ running but can't seem to find any templates except an old one for CUCM 4 (windows). Any help would be appreciated!
12-28-2010 12:13 PM
Do you need historical information or real time? If you're looking for real time information, have you looked at what's available to you via the RTMT tool?
Cliff
01-05-2011 07:43 AM
Yes, the RTMT is very helpful for live usage but historical is what i'm aiming for. Also i'd like to break it down by PRI and not just by CUC, cluster. To my knowledge the RTMT only monitors the cluster's calls by total and doesn't break them down.
01-06-2011 12:41 PM
I think you will need something like Operations Manager. In fact, Operations Manager in combination with Service Statistics Manager would probably be exactly what you need. It just depends on how much you're willing to spend.
01-07-2011 07:31 PM
You can use CDR to graph most gateway utilization. MRTG over Cacti with GW MIBS...
