Beginner
More trouble with Analog DID - inbound digits
I have a DID trunk group of 4 analog groundstart trunk groups configured for wink-start signaling. Verizon now says for sure they are sending all the digits but I am not recieving them correctly, and in fact at this point am only recieving the first digit which is a "2". For reasons know only to them they want to send 10 digits (something about some of the ported numbers beginning with a "0" or "9") so what I should see is 202554xxxx.
I have attached the output of "show vpm signaling" and "Show voice-port 0/3/0" which is one of the trunks. If anyione who know more then me could sanity-check this and verify they don't see anything amiss it would be great!
7 REPLIES 7
Contributor
Re: More trouble with Analog DID - inbound digits
I don't see your debug output. Also, you say, "groundstart trunk groups configured for wink-start signaling" There technically is no such thing that I have ever heard of. Analog DID should be E&M wink start normally, although the options to wink start are sometimes 'immediate start' or 'delay dial' So, it could possibly be a configuration error if you have DID trunks configured as ground start.
Also, you can easily test a DID trunk with a test set by simulating the wink. Just connect the test set directly to the port on your router with telco disconnected. You should get a light to indicate battery and if you 'wink' by flashing the test set off hook and on hook you should then be able to dial digits. Not sure about Cisco, but some PBX systems will also give you dial tone and not even require the wink to receive digits like an FXS port.
-- please remember to rate and mark answered helpful posts --
Hall of Fame Master
Hi, probably just a matter of naming things, as there is something commonly called wink-start for analog DID, see a third-party documentation:
http://www.shiprush.com/product_documentation/omnirush/DID__Ordering_the_DID_Phone_Line.htm
Anyway without seeing the traces it's hard to say what the problem could be.
Beginner
Dang, attachment didnt take. Here is the text:
v600-gw#
May 27 17:58:06 EDT: htsp_process_event: [0/3/3, DID_ONHOOK, E_DSP_SIG_1100]did_onhook_offhook htsp_setup_ind
May 27 17:58:06 EDT: [0/3/3] get_local_station_id calling num= calling name= calling time=05/27 17:58 orig called=
May 27 17:58:06 EDT: htsp_process_event: [0/3/3, DID_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]did_wait_setup_ack_get_ack
May 27 17:58:06 EDT: htsp_timer2 - 88 msec
May 27 17:58:06 EDT: htsp_process_event: [0/3/3, DID_WAIT_SETUP_ACK, E_DSP_SIG_1100]did_wait_setup_ack_offhook
May 27 17:58:06 EDT: did_stop_timer
May 27 17:58:06 EDT: htsp_timer_stop
May 27 17:58:06 EDT: htsp_process_event: [0/3/3, DID_WAIT_SETUP_ACK, E_HTSP_EVENT_TIMER2]did_wait_prewink_timer did_offhook
May 27 17:58:06 EDT: [0/3/3] set signal state = 0x6 timestamp = 0 did_onhook
May 27 17:58:06 EDT: [0/3/3] set signal state = 0x4 timestamp = 200
May 27 17:58:07 EDT: htsp_digit_ready(0/3/3): digit = 2
May 27 17:58:07 EDT: htsp_process_event: [0/3/3, DID_OFFHOOK, E_HTSP_PROCEEDING]
May 27 17:58:07 EDT: htsp_process_event: [0/3/3, DID_OFFHOOK, E_DSP_SIG_1100]did_offhook_offhook
May 27 17:58:07 EDT: did_stop_timer
May 27 17:58:07 EDT: htsp_timer_stop wrong offhook eventhtsp_alert_notifyhtsp_call_service_msghtsp_call_service_msg not EFXS (1)
May 27 17:58:09 EDT: htsp_process_event: [0/3/3, DID_OFFHOOK, E_DSP_SIG_0100]did_offhook_onhook
May 27 17:58:09 EDT: did_start_timer: 300 ms
May 27 17:58:09 EDT: htsp_timer - 300 msec
May 27 17:58:10 EDT: htsp_process_event: [0/3/3, DID_OFFHOOK, E_HTSP_EVENT_TIMER]did_offhook_timeout
May 27 17:58:10 EDT: htsp_timer_stop2
May 27 17:58:10 EDT: did_start_timer: 400 ms
May 27 17:58:10 EDT: htsp_timer - 400 msec
May 27 17:58:10 EDT: htsp_process_event: [0/3/3, DID_GUARD_ALL, E_HTSP_RELEASE_REQ]did_onhook_release did_onhook
May 27 17:58:10 EDT: [0/3/3] set signal state = 0x4 timestamp = 0
May 27 17:58:10 EDT: htsp_process_event: [0/3/3, DID_GUARD_ALL, E_HTSP_EVENT_TIMER]did_guard_all_timer
May 27 17:58:10 EDT: htsp_process_event: [0/3/3, DID_PARK, E_DSP_SIG_0100]did_park_onhook
Beginner
Here is the output of "show voice-port summary:
v600-gw#show voice port 0/3/0
Foreign Exchange Station 0/3/0 Slot is 0, Sub-unit is 3, Port is 0
Type of VoicePort is DID-IN
Operation State is DORMANT
Administrative State is UP
No Interface Down Failure
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 3 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 64 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 250 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 10 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for US
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to 600r Ohm
Station name None, Station number None
Translation profile (Incoming): 600MD_10Incoming
Translation profile (Outgoing):
Signal Type is wink-start
In Seizure is inactive
Out Seizure is inactive
Digit Duration Timing is set to 100 ms
InterDigit Duration Timing is set to 100 ms
Pulse Rate Timing is set to 10 pulses/second
InterDigit Pulse Duration Timing is set to 750 ms
Clear Wait Duration Timing is set to 400 ms
Wink Wait Duration Timing is set to 200 ms
Wait Wink Duration Timing is set to 550 ms
Wink Duration Timing is set to 200 ms
Delay Start Timing is set to 300 ms
Delay Duration Timing is set to 2000 ms
Dial Pulse Min. Delay is set to 140 ms
Percent Break of Pulse is 60 percent
Auto Cut-through is disabled
Dialout Delay is 70 ms
Hookflash-in Timing is set to 1 ms
v600-gw#
Highlighted
Hall of Fame Master
I'm a bit puzzled by this:
Not sure why the port goes onhook. Whih exact IOS is this, do you have something else to try ?
Beginner
2801 Software (C2801-IPVOICEK9-M), Version 12.4(23), RELEASE SOFTWARE
Here is the port config:
voice-port 0/3/0
signal did wink-start
Verizon has a tech out and they show they are outpulsing 10 digits. However, when I asked about what timing setting I should be using they started playing stupid.
Anyone have any idea. I am using the defaults for timing but obviously something is not right.
Contributor
Shouldn't did-digit-length 10 be in there? Did you try testing without telco with a phone or test set?
Content for Community-Ad
August's Community Spotlight Awards
