02-23-2011 06:30 AM - edited 03-16-2019 03:37 AM
We are currently running CUCM 7.0(2) and are looking at offloading our CDR records to a reporting server and building our own reports. Does anyone have any links or documents about how to go about this?
I have tried searching for this and found old discussions with links that do not work anymore.
02-23-2011 06:33 AM
02-23-2011 08:02 AM
Thank you. But I was wondering more of what options there are for retreiving call data from the server. We need to create an import process that takes the data and imports it into a new sql server database.
02-23-2011 09:09 AM
I believe you will not be able to have direct access to the informix database in CUCM. Your best bet will be to set up the sftp exports from CUCM to your external database.
hope that helps
02-23-2011 09:13 AM
This would be your other option:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/devguide/7_0_1/ccmdvCh2.html#wp209057
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
