Moving from a 2800 router to a 4300 setup as a SIP to PRI Adapter
EricMartin1951
This is the config from an old 2921 that we are currently using as a SIP to PRI bridge for our FaxCore installation.
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone year
service timestamps log datetime msec localtime show-timezone year
service password-encryption
hostname PRI-Rtr
boot system flash flash0:c2900-universalk9-mz.SPA.157-3.M8.bin
! card type command needed for slot/vwic-slot 0/1
card type t1 0 2
aaa session-id common
clock timezone CST -6 0
clock summer-time CDT recurring
network-clock-participate wic 2
network-clock-select 1 T1 0/2/0
!multilink bundle-name authenticated
isdn switch-type primary-ni
voice-card 0
dsp services dspfarm
voice service voip
ip address trusted list
ipv4 172.x.x.x
ipv4 172.x.x.x 255.255.248.0
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
voice translation-rule 1
rule 1 /^\(9\)\(.*\)$/ /\2/
voice translation-rule 2
rule 1 /^\(0\)/ /2204/
rule 2 /8214/ /2204/
voice translation-profile OPERATOR
translate called 2
voice translation-profile STRIP9
translate called 1
application
global
service alternate Default
vxml logging-tag
no license udi pid CISCO2921/K9 sn FTX1622AKQG
hw-module pvdm 0/0
controller T1 0/2/0
cablelength long 0db
pri-group timeslots 1-24
description ** PRI **
class-map match-all VOICE-AUDIO
match ip dscp ef
class-map match-all VOICE-CONTROL
match ip dscp cs3
match ip dscp af31
policy-map QOS
class VOICE-AUDIO
priority percent 40
class VOICE-CONTROL
bandwidth percent 5
queue-limit 512 packets
class class-default
fair-queue
random-detect dscp-based
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Voice/Fax
ip address 10.xx.xx.x 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
interface GigabitEthernet0/1
description Management
ip address 192.xx.xx.xx
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
interface Serial0/2/0:23
no ip address
encapsulation hdlc
no cdp enable
isdn incoming-voice voice
control-plane
voice-port 0/2/0:23
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 30 pots
destination-pattern .
no digit-strip
port 0/2/0:23
sip-ua
no remote-party-id
retry invite 2
gatekeeper
shutdown
This config will not apply directly to a 4331 with a T1/PRI card.  I did get the hardware to identify and the SPA card boots up, but the voice commands are rejected.
PRI-Rtr(config)#isdn switch-type primary-ni
PRI-Rtr(config)#!
PRI-Rtr(config)#!
PRI-Rtr(config)#voice-card 0
% Invalid input detected at '^' marker.
PRI-Rtr(config)# dsp services dspfarm
Does anyone have an example of doing this on a 4300 series router using the NIM-1CE1T1-PRI card
Is you ISR4K licensed for Voice services?
Going forward please do not post running configuration or other large text output directly into a post. Instead please add it into a text file that you attach to your post. That makes the post much simpler to read and overlook.
Response Signature
Response Signature
EricMartin1951
You are correct sir, after checking this router only has IP base with no voice services enabled. I am working with my partner to get a license for UC now.
