Hello brains trust, I'm looking for some advice or guidance about how to approach a change from POTS to SIP.
Currently there are 5 CME systems located at 5 office locations. There are SIP trunks (via WAN) between each system for internal calls, all external calls are handled by POTS lines locally at each location. Will be moving to a SIP trunk soon for external calls for all locations.
If I terminate the SIP trunk to one of the CMEs is it as simple as adding some dial peers to steer inbound calls to the other CME locations (and vice-versa for outbound calls) .. ? Or would this be better handled by a CUBE ..?
Appreciate any thoughts or suggestions,
Thanks!
