11-30-2017 10:39 AM - edited 03-17-2019 11:42 AM
I am trying to configure in the lab AD LDS (multi forest)
II follow the documentation but get stuck on "Import the Users from AD DC to AD LDS"
The main error is:
C:\Windows\ADAM>ADAMSync /install localhost:50000 c:\windows\ADAM\MS-AdamSyncConf-ADEX1.xml /log -
Establishing connection to target server localhost:50000.
Updating configuration file on c:\windows\ADAM\MS-AdamSyncConf-ADEX1.xml.
Reading Configuration File from c:\windows\ADAM\MS-AdamSyncConf-ADEX1.xml
Saving Configuration File on dc=home,dc=local
Attaching configuration file auxilliary class on dc=home,dc=local.
An ldap error occured while saving the configuration file: No Such Attribute
Done.
C:\Windows\ADAM>
Has any one seen this and maybe knows what is going wrong
JH
Solved! Go to Solution.
02-03-2018 12:54 AM
In the meantime I found a solution for my problem: the instructions for CUCM which I received, did not mention the required selection of MS-ADLDS-DisplaySpecifiers.LDF. Here is a screenshot of the instruction for a Windows 2012 environment (for a Windows 2003/2008 Cisco did select the MS-ADLDS-DisplaySpecifiers.LDF, but not for W2K12):
The instruction only mentions 4 LDF's, not 5.
For ADAM/LDS Bind Redirection Features you need at least the MS-ADLDS-DisplaySpecifiers.LDF (and MS-UserProxy.ldf)
When I added MS-ADLDS-DisplaySpecifiers.LDF with ldifde.exe this problem was solved.
01-31-2018 03:12 PM
I've got the same problem:
Adamsync.exe v1.0 (6)
Updating configuration file on C:\Windows\ADAM\xxxx\MS-AdamSyncConf-xxxx.xml.
Reading Configuration File from C:\Windows\ADAM\xxxx\MS-AdamSyncConf-xxxx.xml
Saving Configuration File on dc=xxxx,dc=com
Attaching configuration file auxilliary class on dc=xxxx,dc=com.
Done.
Done.
Were you able to solve it?
02-03-2018 12:35 AM
Still not found the solution
Working some of my Microsoft colleagues to solve it
jan
02-03-2018 12:54 AM
02-03-2018 04:30 AM
Let me try this tomorrow in my LAB
Thanks for the update!
Jan
06-18-2018 12:26 AM
hi There,
Any luck ?
I am also stuck at exact same step. please help.
thank you
06-19-2018 03:25 AM
06-19-2018 09:30 AM
07-05-2018 03:13 AM
07-08-2018 10:27 PM
hi Helweg,
I was able to make it work , thanks for your response though. Much appreciated.
