11-30-2018 04:59 AM - edited 03-17-2019 01:47 PM
Hi all,
I'm not able to get my MTP registered in cucm, ive configured sccp /groups/dspfarm however no succes:
Registration status in cucm (Unknown)
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/0/0
IPv4 Address: 123.45.67.89
Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 12.34.56.78, Port Number: 2000
Priority: 1, Version: 7.0, Identifier: 2
Priority: 2, Version: 7.0, Identifier: 1
MTP Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
Active Call Manager: NONE
TCP Link Status: CONNECT_PENDING, Profile Identifier: 2
Reported Max Streams: 200, Reported Max OOS Streams: 0
Supported Codec: pass-thru, Maximum Packetization Period: N/A
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period : 30
TLS : ENABLED
DSP groups on slot 0/4 slot id 4
dsp 1:
State: UP, firmware: 40.2.10
Max signal/voice channel: 32/32
Max credits: 480, Voice credits: 480, Video credits: 0
num_of_sig_chnls_allocated: 0
Transcoding channels allocated: 0
Group: FLEX_GROUP_VOICE, complexity: FLEX
Shared credits: 480, reserved credits: 0
Signaling channels allocated: 0
Voice channels allocated: 0
Credits used (rounded-up): 0
Slot: 0/4
Device idx: 0
Dsp Type: SP2700
sccp local GigabitEthernet0/0/0
sccp ccm 10.12.34.56 identifier 1 priority 2 version 7.0
sccp ccm 10.12.34.78 identifier 2 priority 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0/0
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register TEST1-MTP1
associate profile 2 register TEST2-MTP2
dspfarm profile 1 mtp
codec g711ulaw
codec pass-through
maximum sessions software 100
associate application CUBE
dspfarm profile 2 mtp
codec g711ulaw
codec pass-through
associate application SCCP
In cucm i gave it the same name (TEST1-MTP1) (TEST2-MTP2)
And put it in a devicepool
Am i missing something in my configuration part or what??
11-30-2018 06:38 PM
Your LTI MTP won’t register to cucm (assoc app cube) but the other one should. You might try bouncing sccp (no sccp; sccp).
12-03-2018 01:58 AM
