Multi forest LDAP and Extension mobility
mthijssen
hello,
We want to support the following configuration:
MultiForest LDAP integration with CUCM 10.5.
So we want to set the "LDAP Attribute for User ID" on UserPrincipalName (UPN). > userid@domain.com
We also want to support Extension Mobility.
Is there a way to make te login proces easier than logging in with userid@domain.com and the PIN code?
Jaime Valencia
Unfortunately no, the EM process uses whatever you chose for userID for the login.
java
if this helps, please rate
