10-25-2015 02:37 AM - edited 03-17-2019 04:41 AM
We have a new setup , where we have :-
1. Informacast Paging Server in Vlan 10 of Core Switch ( Paging Server IP : 10.10.10.18 )
------ Server Vlan SVI IP Address - 10.10.10.1 (Core Switch 6509 )
2. IP Phones in Vlan 20 of Access Switches ( 3750 Access Switches Connected to Core Switch 6509 by TRUNK )
------ Voice Vlan SVI IP address - 10.10.20.1 ( on Core Switch 6509 ) and no Voice vlan SVIs on 3750 access Switches.
------ 3750 Access Switches are connected to 6509 Core Switch by Trunk Port.
Need to configure Multicasting from Paging Server(Vlan 10) to IP Phones (Vlan 20) . Can anyone give a simple and clear configuration for this ?
11-18-2015 01:18 PM
I am working off of the following:
03-31-2016 06:22 AM
I managed to get this working by configuring PIM (passive, sparse or dense mode) on the server and phone VLANs (VLANs 10 and 20 in your case) and configuring a RP address of the SVI in the phone VLAN (ip pim rp 10.10.20.1 in your case) Plus turn on multicast routing of course.
Hope that helps.
02-02-2019 12:06 AM
can you elaborate and give the exact commands which you ran
03-20-2019 11:39 AM - edited 03-20-2019 12:24 PM
Below is the configuration:
On Core or Layer-3 Switch:
Core#config t
Core(config)#ip multicast-routing
Core(config)#
Core(config)#interface vlan10
Core(config-if)#ip address 10.10.10.1
Core(config-if)#ip pim sparse-dense-mode
Core(config-if)#ip igmp version 3
Core(config-if)#
Core(config-if)#interface vlan20
Core(config-if)#ip address 10.10.20.1
Core(config-if)#
Core(config-if)#exit
Core(config)#
Core(config)#ip pim rp-address 10.10.10.1
Core(config)#
Core(config)#ip pim rp-candidate vlan20
Core(config)#
Core(config)#end
Core#
Depending on the test results, you may need add below configuration on Layer-2 Switch where IP Phones are connected:
On Layer-2 Switch:
Access#config t
Access(config)#ip igmp snooping
Access(config)#end
Access#
