01-13-2016 03:05 AM - edited 03-17-2019 05:28 AM
Hi everybody,
Ours is a very small setup with only one outside line connecting to voiceport, we are having auto attendant configured.
Now we are adding one more FXO line to our network, but when call comes on that line, all the calls should be forwarded to particular number say 2001.
If auto attendant is running, all calls are going directly to auto attendant and playing welcome message.
please help me in this ASAP and also how to reserve the new FXO port for only 2001 both incoming and outgoing.
PLEASE HELP
Solved! Go to Solution.
01-13-2016 03:12 AM
If you want all incoming calls on second FXO gets forwarded to 2001, you need to use connection plar command under voice port.
Use Class of Restrictions (CoR) if you want only 2001 to use second FXO port. No additional care is required to reserve for incoming calls as 'connection plar 2001' command will ensure that all incoming calls gets routed to 2001.
- Vivek
01-13-2016 03:12 AM
- Vivek
01-13-2016 03:17 AM
thanks vivek, i had tried that before and forgot about it, sorry
and for outgoing, you want me to create cor? as we already have cor configured for different people depending on numbers they can call
can you please elaborate on this
01-13-2016 03:21 AM
Please check the following;
https://supportforums.cisco.com/discussion/12738046/cme-3-analog-lines
- Vivek
