11-08-2014 06:13 AM - edited 03-17-2019 12:51 AM
Current Configuration:
ip route 10.230.0.26 255.255.255.255 10.240.23.233
interface GigabitEthernet0/1.1
encapsulation dot1Q 1 native
ip address 10.240.23.234 255.255.255.248
ip traffic-export apply CAPTURE size 10000000
dial-peer voice 3 voip
description OUTGOING SIP Line for Association-A
destination-pattern *9.......
no modem passthrough
session protocol sipv2
session target ipv4:10.230.0.26
voice-class codec 1
This is the configuration of having one SIP line, on our interface having IP 10.240.23.234 and on SIP service provider end having 10.240.23.233.
Whereas SIP Server IP remains the same as said by SIP Service Provider, i.e 10.230.0.26, which is used by in our dial-peers,
Question: One more association is added to the building which want to use different SIP line for calls. No problem I can make different dial-peer for each association-A and association-B as shown below, Where as I can remove 8 after the dial peer 4 is match or when the call is going out, but in both dial-peer I am using the same SIP server i.e 10.230.0.26, so weather a call is coming from association-A or association-B it will direct calls to SIP server IP, so as per the static route we said all packets having destination of SIP server (10.230.0.26) should go to 10.240.23.233 and If we configure for second SIP line we can add this static route i.e
ip route 10.230.0.26 255.255.255.255 10.240.22.2,
So now two route exist for same destination, can anyone give me some hint on it what can be done, how association-A can use association-A line for calls and association-B by using association-B line, I am using SIP trunk between Voice Gateway 2911 and CUCM 8.6.2
I have to give design to management that it can work or not, I am just stuck at this point only, not sure what to do, thank you.
like,
Altered Configuration:
interface GigabitEthernet0/1.2
ip address 10.240.22.1 255.255.255.248
voice-class codec 1
dial-peer voice 4 voip
description OUTGOING SIP Line for Association-B
destination-pattern *89.......
voice-class codec 1
PFA the diagram, thank you.
Kind Regards,
Waleed khan
11-09-2014 07:41 AM
Hi All,
Is it possible to solve this by using NAT at SIP service provider. I mean I'll use different IP under my dial-peer for different association. Like,
session target ipv4:1.1.1.1
voice-class codec 1
session target ipv4:2.2.2.2
voice-class codec 1
and
ip route 1.1.1.1 255.255.255.255 10.240.23.233
ip route 2.2.2.2 255.255.255.255 10.240.22.2
So is it possible at SIP service Provider that they will do NAT and traffic for 1.1.1.1 will be NATED to
10.230.0.26 and for 2.2.2.2 will be NATED to 10.230.0.26.
Kind Regards,
Waleed Khan
11-11-2014 10:28 PM
Dear All,
Can someone please look into this issue for me, thank you.
Kind Regards,
Waleed Khan
11-12-2014 12:07 AM
dial-peer voice 8863 voip
corlist outgoing PT-Intl
description SIP to ///Cell ///01.. ///02..
translation-profile outgoing ///cell_out_sip///
preference ..
max-conn .5
no shutdown
destination-pattern ///7........
session target ipv4://5./7.//5./7
voice-class sip bind control source-interface GigabitEthernet0/0.310
voice-class sip bind media source-interface GigabitEthernet0/0.310
11-16-2014 07:48 AM
Dear Tagir,
Thank you for reply, can you please contribute here more by explaining please.
- Waleed
11-16-2014 07:49 AM
Do I have to use CUBE, can you please explain if you can contribute here, thanks.
- Waleed
11-16-2014 10:03 AM
http://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-border-element/white_paper_c11-613550.html?cachemode=refresh
I just get to it, let see, if this works or not.
