10-11-2016 03:25 AM - edited 03-17-2019 08:19 AM
Hi all;
How can i create and configure multiple VLAN Voice in CME?
Thanks in advance,
10-11-2016 05:40 AM
Hi Moussa,
Can you help us understand where the phones are connected and what is the exact topology? Do you want to configure IP phones connected to switch in two different VLAN's? If that is what you want then you can create two Voice VLAN on the switch, create a trunk with the CME router allowing traffic for both VLAN and configure intervlan routing on it.
You may refer to the link below:
http://www.cisco.com/c/en/us/support/docs/lan-switching/inter-vlan-routing/14976-50.html
Aseem
(Please rate if useful)
10-11-2016 07:26 AM
hi Aseem, thanks for your repley
but the problem is in source-address ip under "voice register global" which one i should put because i have 2 vlans
g0/0.1
encapsulation dot1q 60
ip address 100.30.60.1 255.255.255.0
g0/0.2
encapsulation dot1q 70
ip address 100.30.70.1 255.255.255.0
ip dhcp pool voice-60
network 100.30.60.0 255.255.255.0
default router 100.30.60.1
option 150 ip 100.30.60.1
ip dhcp pool voice-70
network 100.30.70.0 255.255.255.0
default router 100.30.70.1
option 150 ip 100.30.70.1
voic register global
source-address x.x.x.x ???
thanks in advance
MM
10-11-2016 07:51 AM
Best would would be to configure a loopback interface on the CME and use that address as the source address.
Aseem
10-11-2016 07:59 AM
thanks Aseem,
in my case the configuration of loopback interface is like that:
interface loopback 0
ip address x.x.x.x
am i right?
10-11-2016 08:13 AM
Yes, you are correct! You need to make sure you can ping the loopback IP from switch as well try to ping one of the phone's from both the subnet using the source address of loopback to make sure connectivity is bidirectional.
Ping X.X.X.X source loopback0
Aseem
(Please rate all the useful posts)
10-11-2016 10:53 AM
hi Aseem,
I tried to ping from pc to the loopback but there aren't a connection between them what shoud do?
thanks
10-12-2016 01:18 AM
Hi Moussa,
If you are not able to ping the loopback IP address from your PC then you need to check the routing. Can you ping the two IP addresses "100.30.60.1" & "100.30.70.1" from your PC as well as from the switch?
Also do a trace route.
Aseem
10-19-2016 07:13 AM
thanks Aseem i will test that
