01-21-2016 04:23 PM - edited 03-17-2019 05:36 AM
Using CUCM 8.03
1. Can multiple wav files be added for MOH?
2. If so, can these wav files be looped so that they play in a sequence?
01-21-2016 04:31 PM
1, yes
2, no
You choose one MOH file, and whoever you put on hold, will always hear that same MOH.
01-21-2016 11:39 PM
Thanks Jaime. Do you know of a third party application that can play multiple wave files in sequence? Our client would like to record different announcements in different files that are played while callers are on hold. Any info is appreciated.
01-22-2016 01:26 AM
Hi Richard,
If you are using physical MCS servers (rather than virtual) you can plug a USB dongle into a CUCM server and play audio files stored on an iPod (or similar device). The challenge will be finding the USB dongle as I do not believe Cisco still sell them. The Cisco part code for the adapter was MOH-USB-AUDIO=
More details are below:
If you are running virtual servers (or cannot source a USB adapter) then you can stream multicast MoH (not unicast) using an external device to stream the audio from an iPod or similar device.
This device could be a Cisco gateway with an FXO or E&M card or (preferably) a dedicated device from a company like Barix.
Chec out Willam Bell's blog on this topic.
http://www.netcraftsmen.com/live-stream-music-on-hold-and-cisco-uc-on-ucs/
Hope this helps
James
01-22-2016 01:24 PM
Thanks everyone for the information!
01-22-2016 04:54 AM
Hi, if you have uccx or cue ivr, then you can create custom script to play moh files as required
01-22-2016 07:07 AM
If you're not running on MCS, you cannot do as James says, your option would be to use live MOH via multicast from an ISR, or buy a multicast injector for your network to which you would attach the mp3 player.
