07-06-2018 07:47 AM - edited 03-17-2019 01:09 PM
I have a cucm v11.5 installed with gateway cisco ISR 4321,
the music on hold work fine in internal call, but not working on external call it head the beeps .
can you help me please the resolve this problem?
Best regards
Akram
07-06-2018 07:53 AM
07-06-2018 08:37 AM
07-06-2018 08:24 AM
07-06-2018 11:09 AM
By default UCM only offers the g711 ulaw for Music on Hold
Go to System/Service Parameters and select "Cisco IP Voice Media Streaming App"
Check that all Codecs are selected
Graham
07-06-2018 11:49 AM
Thank you for your reply
I have all codec selected on cucm 11.5.
The problem is present only on external call.
Best regards
07-06-2018 11:55 AM
I only hear a beep
Best regards
07-06-2018 11:53 AM
I am not changing any codec . I kept the default config .
Best regards
07-08-2018 10:28 AM
This is not a fault or a problem. The system has been setup this way and it's because of conference calls. If someone is on a conference call and they put their phone on hold they flood the conference bridge with music so no one can hear.
If you set the network hold to a nonexistent audio stream then the system will play the beeps instead of music.
If you want to restore music you will need to work out how it has been disabled.
Normally it is done by selecting a none existent MOH stream
Go to Service Parameters/Cisco CallManager
Check the Default Network Hold MOH Audio Source ID and Default User Hold MOH Audio Source ID are set to a valid MOH stream, normally 1
Graham
07-09-2018 04:11 AM
thank you for your reply and your informations.
I resolved the problem by adding the codec G.711 on gateway isr
Best regards
