Music On Hold Refuses to Work
ccentbound
I have been trying for weeks to get music on hold to work.  Can someone please be kind enough to tell me what I am doing wrong?  The Show Flash and the Telephony-Services portion of the running config are below.  Thank you for whatever help you can provide.
__CME_Voice___#show flash
-#- --length-- -----date/time------ path
1     12856458 Nov 7 2011 00:00:20 -04:00 2pacIAin'tMadAtChaInstru.wav
2     35441852 Nov 6 2011 06:57:22 -04:00 c2801-ipvoicek9-mz.124-15.XY5.bin
15585280 bytes available (48300032 bytes used)
__CME_Voice___#
telephony-service
load 7910 P00405000700
load 7960-7940 P0030702T023
max-ephones 30
max-dn 100
ip source-address 172.16.1.1 port 2000
system message CISCO ROCKS !!!!
max-conferences 4 gain -6
moh 2pacIAin'tMadAtChaInstru.wav
web admin system name Batman
dn-webedit
time-webedit
transfer-system full-consult
directory entry 1 5005 name Fax Hallway
create cnf-files version-stamp 7960 Nov 11 2011 16:58:01
ephone-dn  1  dual-line
number 1001
pickup-group 1101
name Jeff
ephone-dn  2  dual-line
number 1002
name Mark
ephone-dn  3  dual-line
number 1003 secondary 3215551003
name Tommy
ephone-dn  5  dual-line
number 1005
name Tommy
ephone-dn  6  dual-line
number 1006
name Erick
ephone-dn  7  dual-line
number 1007
name Chrystal
ephone-dn  8  dual-line
number 1008
ephone-dn  10  dual-line
number 1010
name Justin
huntstop channel
no huntstop
ephone-dn  11  dual-line
number 1010
preference 1
huntstop channel
ephone-dn  13  dual-line
number 1013
ephone-dn  14  dual-line
number 1014
ephone-dn  15  dual-line
number 1015
pickup-group 1101
name Janique
ephone-dn  21
number 3001
park-slot timeout 90 limit 5
ephone-dn  22
number 3002
park-slot
ephone-dn  25  dual-line
number 1025
pickup-group 1101
name Emily
ephone-dn  30
number A100
intercom A101 label "Manager"
ephone-dn  31
number A101
intercom A100 label "Assistant"
ephone-dn  70
number 1070
ephone-dn  88  dual-line
number 1000
ephone  1
mac-address 0026.CBBE.91A9
button  1:1 2:2 3:3
ephone  3
mac-address 000A.B756.7E86
button  1f88
ephone  4
mac-address 0014.22B8.965D
button  1:5 2:6
ephone  5
mac-address 0026.B923.C752
button  1:7 2:10
line con 0
exec-timeout 0 0
password cisco
logging synchronous
login
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
exec-timeout 0 0
logging synchronous
no login
scheduler allocate 20000 1000
ntp clock-period 17179890
ntp master
ntp server 130.207.244.240
ntp server 71.40.128.157
end
Karthik Sivaram
Level 4
Level 4
hi Edward,
Try using the sample audio file instead of  the customized file your using.
If  the sample audio file  works then  the  specs of the customized file need to be checked.
-Karthik
Sir,
Thank you for taking the time to respond.
Unfortunately, I have no idea what you are talking about.  What is a sample audio file?
I am using the IOS - - > c2801-ipvoicek9-mz.124-15.XY5.bin
I don't think this IOS has a sample audio file.
The .tar files have audio files when they are extracted.
If the image that I am using has a sample audio file, can you kindly tell me how to use it?
Thank you very much for your help.
The most likely problem is that the wav file you have uploaded is not in the correct format.
Convert the wav file to CCITT ulaw (g711ulaw) format.  8khz, 8-bit, mono.  Then try it again.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemoh.html#wp1010384
Configuring Music on Hold from an Audio File
To configure MOH when you are using a file to supply the audio stream, perform the following steps.
Prerequisites
SIP phones require Cisco Unified CME 4.1 or a later version.
A  music file must be in stored in the router's flash memory. This file  should be in G.711 format. The file can be in .au or .wav file format,  but the file format must contain 8-bit 8-kHz data; for example, ITU-T  A-law or mu-law data format.
