Highlighted
Enthusiast
mva do not heard anyhing when teh calls is connect
Hello I need to know why I do no heard anything when I dial from of pstn>GW H.323 > MVA
I have this configured :
dial-peer voice 6098 pots
service mva
incoming called-number 6098
direct-inward-dial
no digit-strip
port 4/0/0:0
dial-peer voice 76708 voip
preference 1
destination-pattern 6098
voice-class h323 1
session target ipv4:10.40.7.2
dtmf-relay h245-alphanumeric
codec g711ulaw
ip qos dscp cs5 media
no vad
application mva
http://10.40.7.1:8080/ccmivr/pages/IVRMainpage.vxml
I have debug debug voice application vxml application attached
anyone can help me?
6 REPLIES 6
Highlighted
Beginner
Do you have 3336796000 configured as a remote destination for any user? IS MVA enabled for that user's configuration?
How long does it take before the call is dropped?
Highlighted
Hello, I do not have configured this number as remote destination , 3336796000 is my caller id of PSTN, the calls is dropped at one minute without heard IVR.
Highlighted
Have you configured the 6098 number as your MVA on CUCM and also in your service parameters. Is the service enabled as well ?
Highlighted
Yes, I have attache my config.
Highlighted
I have other info:
G_3845#sh call application voice mva
Script Name : mva
URL : http://10.40.7.1:8080/ccmivr/pages/IVRMainpage.vxml
Type : Service
State: Registered
Life : Configured
Exec Instances: 0
Script Code Begin:
VXML Application mva
URL=http://10.40.7.1:8080/ccmivr/pages/IVRMainpage.vxml
Security Level: not trusted
27 incoming calls
0 calls handed off to it
0 call transfers initiated
0 pages loaded, 54 successful
0 prompt play attempts, 0 successful
0 recorded messages
The VXML Script is:
http://10.40.7.1:8080/ccmivr/IVRCalleridLookup.do" method="get" namelist="remotedest srcdir"/>
http://10.40.7.1:8080/ccmivr/IVRCalleridLookup2.do" method="get" namelist="dest srcdir accessCount"/>
Highlighted
Did you find a solution? I'm getting the same error. Call is conected but not prompt it hears, after some second the call is dropped...
Any advice would be appreciated
_____________________________
MDGDP, CCNA, CCNA Voice certified
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
Content for Community-Ad
