MWI for Broadcast Voicemail
pcarey
Is it possible to configure the message waiting indicator light for a broadcast message with Call Manager and Unity Connection version 10.5.2.10000-5 ?
Jaime Valencia
java
if this helps, please rate
Rob Huffman
Hi there,
Just to add a note to the tips from my friend Java (+5), the workaround for this MWI limitation is generally to use System Distribution lists (all voicemail users) to send a "broadcast type" message that will light MWI lamps. You can control who has access to send these type of messages by using access lists from Advanced config;
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/administration/guide/10xcucsagx/10xcucsag230.html#pgfId-1052796
Cheers!
Rob
