MWI issue with CME and CUE running on seperate routers
tyoungbauer
I cannot get the MWI lights to work on the phones.
here is the dial peer on the CME router
dial-peer voice 1001 voip
destination-pattern 900.....
session target ipv4:172.22.12.250
codec g711ulaw
no vad
Here are the ephones
ephone-dn 190
number 9000....
mwi on
ephone-dn 191
number 9001....
mwi off
Here is part of the config on the CUE router
codec g711ulaw
no vad
telephony-service
load 7910 P00403020214
load 7960-7940 P00303020214
load ATA ATA030100SCCP040211A.zup
max-ephones 48
max-dn 192
ip source-address 172.16.11.254 port 2000
create cnf-files version-stamp 7960 Aug 06 2007 11:47:32
max-conferences 8
timeouts interdigit 5
moh music-on-hold.au
web admin system name admin password want0p3n
dn-webedit
time-webedit
ephone-dn 190
number 9000....
mwi on
ephone-dn 191
number 9001....
mwi off
also ccn application
tllcvmrouter> sh ccn application
Description: ciscomwiapplication
Script: setmwi.aef
ID number: 0
Enabled: yes
Maximum number of sessions: 8
CallControlGroupID: 0
strMWI_OFF_DN: 9001
strMWI_ON_DN: 9000
If i dial 90002765 the phone extention the system lights the phone. If I dial 90012765 theextention it unlights the phone.
I also have SMTP forwarding turned on and VM's are getting to the VM system as well as email. I just cannot get the MWI to work.
Todd
7 Replies 7
Rajesh Revuru
Level 4
Level 4
Hi:
I think the communication between CME and CUE is SIP based. So i guess you would have to include under your dial-peers
session protocol sipv2
dtmf-relay sip-notify
codec g711ulaw
And also session target IP address has to IP Address of CUE.
I had that in there in the past with no luck. I added again and still no light. As for the session target should it be the router IP or the CUE module IP?
IP address should be the CUE module --
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/integration/unity_exp/configuration/guide/cue_cme1.html#wp1112746
SUMMARY STEPS
1. dial-peer voice tag voip
2. destination-pattern [+] string [T]
3. session protocol sipv2
4. session target ipv4:destination-pattern
5. dtmf-relay sip-notify
6. no vad
7. exit
destination-pattern-IP address of the dial peer that is to receive calls. Enter the IP address of the Cisco Unity Express module.
also check sip-gateway in CLI config of CUE..
Should CUE be accessable from both routers? Or just from CCME? Refraised; is CUE-router also VOIP-enabled besides the dialpeer to CUE?
jarmitage
Hi Todd,
I thought I'd come across this before. Take a look at this thread, it may be of use to you:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=General&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cbf180d/4#selected_message
Cheers,
-James.
Please rate helpful posts...
Thanks in advance to everyone
I still cannot get the VM light to light up. I can dialing the MWI number 8000 and off dialing 8001. Here is the configs from both (with some info removed).
This is the CCME router
isdn switch-type primary-ni
voice call carrier capacity active
voice rtp send-recv
voice service voip
h323
sip
controller T1 1/0
framing esf
linecode b8zs
pri-group timeslots 13-24
gw-accounting syslog
interface Serial1/0:23
no ip address
no ip redirects
no ip unreachables
no logging event link-status
isdn incoming-voice voice
no cdp enable
router eigrp 100
network x.x.0.0
auto-summary
ip classless
ip http server
ip http path flash
control-plane
voice-port 1/0:23
dial-peer voice 100 pots
description inbound and outbound to PSTN
destination-pattern 9.T
direct-inward-dial
port 1/0:23
dial-peer voice 8991 voip
description CUE Voice Mail System
destination-pattern 8991
session target ipv4:x.22.12.250
codec g711ulaw
no vad
dial-peer voice 8010 voip
description AtuoAttendent_recoreded message
destination-pattern 8010
codec g711ulaw
no vad
dial-peer voice 8011 voip
description AutoAttendent
destination-pattern 8011
codec g711ulaw
no vad
dial-peer voice 8000 voip
destination-pattern 8000....
dial-peer voice 8001 voip
destination-pattern 8001....
no vad
gateway
timer receive-rtp 1200
sip-ua
mwi-server dns:voicemail expires 3600 port 5060 transport udp unsolicited
telephony-service
load 7960-7940 P00308000700
max-ephones 52
max-dn 200
ip source-address x.16.11.254 port 2000
caller-id block code *67
timeouts interdigit 3
timeouts ringing 30
system message Welcome Todd
url services http://x.16.11.253/voiceview/common/login.do
url authentication http://x.16.11.253/voiceview/authentication/authenticate.do
time-zone 8
create cnf-files version-stamp 7960 Sep 12 2007 11:47:42
voicemail 8991
mwi sip-server x.22.12.250 transport udp port 5060 reg-e164
mwi expires 86400
max-conferences 8 gain -6
call-forward pattern .T
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 8...
transfer-pattern 111.
login timeout 600 clear 01:00
ephone-dn 180
number 7999
ephone-dn 190
number 8000.... secondary 8001....
mwi on-off
This is the CUE router
voice service voip
h323
sip
interface Loopback0
no ip address
interface FastEthernet0/0
ip address x.16.11.253 255.255.255.0
interface Service-Engine1/0
ip address x.22.12.254 255.255.255.0
ip route-cache flow
service-module ip address x.22.12.250 255.255.255.0
service-module ip default-gateway x.22.12.254
ip route x.22.12.250 255.255.255.255 Service-Engine1/0
ip http server
dial-peer cor custom
telephony-service
max-ephones 48
max-dn 192
ccn application ciscomwiapplication
description "ciscomwiapplication"
enabled
maxsessions 8
script "setmwi.aef"
parameter "CallControlGroupID" "0"
parameter "strMWI_OFF_DN" "8001"
parameter "strMWI_ON_DN" "8000"
end application
Todd
crehrer
Not sure if you got this working yet but I have the same situation at one of my locations, so where the CUE is you need to build out two VOIP dial peers this is how I have mine working, I have 5 digit dialing and my numbers are in a range at the other site hope this helps.
dial-peer voice 3765 voip
description MWI To Logistics
destination-pattern 80003765.
session target ipv4:10.3.204.1
codec g711ulaw
no vad
dial-peer voice 3766 voip
destination-pattern 80013765.
codec g711ulaw
no vad
