MWI Issues Cisco Unity 8
Okechi Awujo
Beginner
Beginner
Hi Guys
I am having some issues with MWI on unity 8. (CUCM Version 8.0) They dont come on or off .. however the email notification works fine.. in  the windows  event viewer i get  a CiscoUnity_Notifier :
Failed to set message waiting lamp for username, ext 4221, switch 0, cluster 0, reason: SetMWI failed with [0x80004005; E_FAIL].
I Have resync'd the MWI no joy.. anyone seen this before?? any help will be appriciated
Okechi
11 Replies 11
Jaime Valencia
Was this working before??
Have you checked all the basics?? MWI DNs match on both sides, MWI DNs do work, CSS, partitions, etc??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
