MWI light not working
Paul Harris
Hi All
I'm having a bit of a problem with some users finding that the MWI on their phone isn't lighting up when they have a voicemail. The users all seem to be limited to one particular partition/css. However, it has only stopped working in the last couple of days and as far as I'm aware nothing in the setup has changed.
Additionally, if they ring the MWI on/off extensions, the light comes on and off fine. Any ideas?
Paul
9 Replies 9
paolo bevilacqua
Maybe mention th VM system and version are you using ?
Sorry yeah it's Unity 5.5 Build 5.0(1)
Leonardo Santana
What type of Unity are you using?
On the CCM the MWI ON and OFF are configured correct? On the Unity the MWI ON and OFF are the same numbers
Leonardo Santana
*** Rate All Helpful Responses***
Yep, I've checked the MWI on and off numbers on CCM and Unity.
Cheers
Paul
Paul,
Have a look at this link
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_tech_note09186a0080711ae3.shtml
I think your issue may be down to the Unity VM ports CSS not being able to
see the phones partition
Alex
Regards, Alex. Please rate useful posts.
Good suggestion. As it turned out, the CSS for the unity ports did not include the partition with the phones. However, I have rectified this and it is still not working
Do I need to restart anything to see the change?
Hi Paul.
Calling from an IP Phone MWI On/Off numbers, does the light work?
Let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Yes it does. This is what confuses me!
Paul
Hi Paul.
Did you had a look to this guide?
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/troubleshooting/guide/ex/5xcutsg080e.html#wp1049490
Carlo
