MWI madness - UC560/7965 handsets
davidfield
Participant
Participant
Hello All,
I'm positive I've read and tried almost every recommendation on Message Wait Indicator to get it to work on my 7965 handsets with UC560.
I can leave a voicemail at the extension 210.  I can dial 399 and listen to my voicemails from extension 210. I can see the A800 in the ccsip debug being sent to 210.  I'll put this out there but surely I don't need to reboot the phone or uc560 after making the changes to resync MWI.
The entries in the service engine config match the ephone settings on the config.
I've attached:
- UC560 config
- SIP ccsip debug
- Service Module config
Any pointers greatly appreciated.
David
7 Replies 7
davidfield
Participant
Participant
Below is the debug after hangup of leaving voicemail message.  In bold underlined below is the MWI send "ON".  So totally confused now.  Any ideas anyone?
004217: Aug 11 12:39:31.894: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x01
        Cause i = 0x8090 - Normal call clearing
        Progress Ind i = 0x8288 - In-band info or appropriate now available
004218: Aug 11 12:39:31.894: %ISDN-6-DISCONNECT: Interface BRI0/1/0:1  disconnected from unknown , call lasted 19 seconds
004219: Aug 11 12:39:31.898: //804/BFFA590489AB/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:399@10.1.10.1:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;x-route-tag="tgrp:ALL_BRI";branch=z9hG4bK15A336
To: <399>;tag=ds91ee3860
Date: Thu, 11 Aug 2011 12:39:12 GMT
Call-ID: BFFAF52C-C34D11E0-89AECA6B-19482E35@10.1.10.2
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1313066371
CSeq: 102 BYE
Reason: Q.850;cause=16
Content-Length: 0
004220: Aug 11 12:39:
