12-11-2017 05:17 AM - edited 03-17-2019 11:45 AM
We are running 2 Unity servers 10.5.2.12901-1. This morning, the MWI wasn't working on hard phones, so I restarted the Connection Notifier on the publisher. Bam, the MWI comes back, but I notied Connection Notifier was disabled on the subscriber along with several other services. Is it okay to activate the Connection Notifier on the subscriber? If so, will there be any issue with my Unity set up?
Any help is appreciated. Thanks.
Solved! Go to Solution.
12-11-2017 10:27 AM - edited 12-11-2017 10:29 AM
Hi there,
My friend Chris is most correct here (+5).
Here's a note from an older CUC doc that does speak to this query;
Table 3-1 Server Status Functions in the Cisco Unity Connection Cluster
12-11-2017 05:44 AM
Some CUC services such as Notifier only are active on the primary active server, so activating it on the other service will deactivate it on the one that is running it, so you should not activate it. During failover testing you can notice the behavior.
Hi there,
