12-12-2006 12:20 PM - edited 03-14-2019 07:11 PM
Backing up the publisher server we normally have a 680 mb backup. There haven't been any particular dramatic changes. A user update here and a user update there. All of a sudden my backup is 1.26 gb. Any ideas?
Solved! Go to Solution.
12-12-2006 12:34 PM
Hi Ross,
The size of the backup will vary due mainly to the volume of CDR records. You probably have the system set to purge the records at a specific time. This is why the backup size could be quite high one week (before purge) and quite low the following week (after purge). Here is a great explanation of the backup file size from Gonzalo@Cisco;
Hope this helps!
Rob
12-12-2006 12:34 PM
Hi Ross,
Hope this helps!
Rob
12-12-2006 01:10 PM
Very good. Makes sense. Thank you for your help. Much appreciated.
12-12-2006 01:26 PM
Are you backing up CDR?
I've experienced it before where CDR had been turned on in the callmanager but was not functioning. A subsequent reboot caused CDR to function.
If this is your case and you are in fact backing up CDR, depending on call volume, your backup size could skyrocket.
later,
Go0se
