12-07-2016 12:42 AM - edited 03-17-2019 08:52 AM
Hi all,
Is there any reporting for the native call queuing is available in CUCM 11.x ?
For example, how many calls answered by agents, how many calls missed or for how long caller waited into queue ?
12-07-2016 01:13 AM
Hi Ilana,
You may need to filter the CDR output as per the following
http://www.gossamer-threads.com/lists/cisco/voip/167842
Manish
12-07-2016 01:41 AM
Hi manesh
Thank for quick reply. I been through this link earlier but as you know cdr section has several reports im not sure which cdr report will have native call queue details.
Could you please advise ?
12-07-2016 01:54 AM
You can either run a CDR search by User/Phone Number/SIp URL as explained in an example in the following link for native call queuing
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/9_1_1/cdrdef/CUCM_BK_C268EF1B_00_cucm-cdr-admin-guide-91/CUCM_BK_C268EF1B_00_cucm-cdr-admin-guide-91_chapter_011.html#CUCM_RF_N8251834_00
In CAR tool, under CDR > Search > By User/Phone No/SIP URL
The phone number or SIP URL displays in the Phone Number/SIP URL(s) box.
You will need to analyze each CDR record , try using a filter to scan for CDR's with
wasCallQueued value of 1.
Manish
12-12-2016 02:11 AM
Hi Manish,
I got the CDR Reports with " wasCallQueued " I am checking records one by one, how to apply filter in CDR to look for all calls having wasCallQueued vlaue of 1 ?
12-13-2016 03:24 AM
With CAR tool there is no way to filter this, you will need to export CDR data and use any third party tool to filter the output for required parameters.
Manish
