Navigation Button Light on Phones?
CiscoMesl
We have a client using a combination of 7821, 8851 and 9951 phones, some of which are in bedrooms.
The backlights are configured to go off early evening but when the backlight goes off, the navigation panel light illuminates and its fairly bright.
Is there anyway to turn this off?
Aaron Harrison
I don't believe so. You could tone it down with a sharpie :-)
Or some other sticker type solution...
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
I had a feeling that might be the case.
Thanks for your reply.
Did you found a real solution for this? Sharpie or sticker are not really working :(
Thanks.
