Highlighted
Beginner
Need a walkthrough on updating firmware on CUCME
It's been 4 years since I last upgraded a CUCME with firmware for VoIP phones, so I am a little rusty.
For example, I want to upgrade the 7942 firmware from SCCP42.8-3-3SR2S to SCCP42.9-2-1S. I think I have to down dsp, jar, and term files, in addition with creating XML and cnf files.
If anyone could talk a little time to spin me back up on this, it would be appreciated. Cisco's white papers weren't much help. Also, I'm not sure if I need to upgrade to a firmware between those version due to the difference
Everyone's tags (3)
1 ACCEPTED SOLUTION
Rising star
Re: Need a walkthrough on updating firmware on CUCME
Hi Michael
Few pointers that should assist here.
  • 8.3(3)SR2S should be able to upgrade directly to SCCP 9.2(1). It's code loads older (and including) 8.3(2) that need an interim load of 8.5(2).
  • Download the ZIP file (the .cop and .exe files are of no use to you) containing the code.
  • Unpack the ZIP file to get the individual file elements.
  • Copy all of these files into your router's flash using copy tftp flash or equivalent.
  • For each file you download, enter a "tftp-server flash:" command in config mode.
  • Issue the following commands on your CUCME
    • config t
    • telephony-s
    • load 7941 SCCP42.9-2-1S
    • no create cnf
    • create cnf
  • debug tftp ev, reset one of your phones and watch the fun proceed in front of your eyes.
HTH. Barry
Barry Hesk
Intrinsic Network Solutions
3 REPLIES 3
Rising star
Hi Michael
    • config t
    • telephony-s
    • no create cnf
    • create cnf
HTH. Barry
Barry Hesk
Beginner
I thought at one point I had to archive a .tar file?
Rising star
Depends on the format of the file you download from CCO. If you grab the same phone firmware under the CallManager download section you can normally find it in ZIP format (compatible with CallManager 4.x). If you download it under CME, then it is in tar. It's the same firmware however
Barry Hesk
Intrinsic Network Solutions.
Content for Community-Ad
August's Community Spotlight Awards
