412
Highlighted
Enthusiast
Need clarification on basic Voice concept
what is default dial-peer? is it being matched or not
what is inbound call leg? its from gateway to CUCM or vice versa
For in coming call, do we need incoming called number. ? if so then why ?
Do we need DID for incoming voip call
Do i want DID on an incoming POTS call.
1 REPLY 1
Highlighted
Beginner
default dialpeer is dialpeer 0, it matches by default if there is no other incoming dialpeer is matched.
whenever call hits the GW, it matches incoming dialpeer , it can be from CUCM or PSTN.
we need incoming dialpeer to define the codec and dtmf digits.
DID is required for incoming POTS dialpeer.
