need help: a typical CUE AA script with 2 language selection in beginning
Lin Zhu
Hi, I am working in CUE AA script , which has 2 different lauguage selection in beginning, then prompt like " press 1 to dial by name, press 0 to reach operator, press 3 for company informaiton, you can dial extension at any time"
could somebody give me a script example for it?
thanks ;
paolo bevilacqua
There are various example script in CUE download area.
Otherwise if you do not want to spend time doing CUE programming, you can use my "universal AA" script that does everything with simple configuration. It can be acquired at the website mentioned in my profile.
Hi Paolo,
What are the differences between your universal aa and B-ACD/AA Enhancements script?
David
"Universal AA" is an .aef script for CUE.
"B-ACD/AA Enhancements" is a TCL/IVR script for IOS.
Sorry to hijack your question Lin
