Need Help for SIP trunking
florentgoue
Hi, I have a 4321 ISR Router,
Cisco IOS XE Software, Version 16.11.01a,
CME 12.6
I want to connect my via a SIP trunk to my ITSP
I can not, I have this message that appears when I configure the SIP trunk/
#credentials username TEST password 0 TEST2019 realm eylim.local
Failed type 6 encryption on password
HARIS_HUSSAIN
1) For 16.11.1 a master key must be pre-configured before configuring type 6 passwords.
2) The master key is not displayed in configuration.
to configure master key using below command
conf t
    key config-key password-encrypt <MASTER PASSWORD>
     password encryptoin <ENCYRPTION TYPE>
If the master key is not pre-configured you get the error  "Failed type 6 encryption on password" Also, type 6 password supports only ENCRYPTED Format and not clear text. So use type 0 while configuring it will be saved as type 6.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
Jaime Valencia
Watch: Updates to SIP Trunking for On-Prem Deployments
https://community.cisco.com/t5/collaboration-documents/voice-of-the-engineer-voe-events/ta-p/3621363
Start at 1:19:06
java
if this helps, please rate
Hi jaime
Thx for your reply, but I can't have access
Access Denied
HARIS_HUSSAIN
conf t
Haris
Hi HARIS
thx for your reply.
Please can you check my question aboutwhitch license do I need ?
Thx
