Need help with moving Overhead Valcom Paging port to Cisco VG204
quadrider1
Hi All,
We are moving over to Cisco CUCM and installing various models of analog gateways to support faxes, bells and paging.  I have setup a VG204 with FXS for a Valcom Paging System.  We have a Valcom 9940 that sits between the VG and the 9 zone paging amp.  When I call the number I hear a ring or two then cuts out.  Still learning how to configure the gateways and I'm wondering if I have something miss configured on the port.  Does anybody have any suggestions as to why this is happening
Much appreciated
Jeremy
Steven L
Did you double check your wiring and Valcom DIP switch settings?
WIRING INSTRUCTIONS Place a check by each step as it is completed.
____ 1. Connect Tip of the Centrex or C. O. Line to pin 16 of the V-9940.
____ 2. Connect Ring of the line to pin 17.
____ 3. Crossconnect pin 6 of the V-9940 to the Tip "WHITE/BLUE" of a Valcom multi-zone dial select
page control unit (such as the V-1109RTVA or V-1109RTHF).
____ 4. Crossconnect pin 7 of the V-9940 to the control unit Ring "BLUE/WHITE".
____ 5. Refer to the Installation Manual supplied with the control unit for speaker and power
connections.
____ 6. Refer to the Installation Manual supplied with the control unit for proper volume adjustment
procedures.
____ 7. Dip Switch Settings: Set dip switches 1 an 8 "ON". Set switches 2 to 7 all "OFF". See Section
titled "Dip Switch Settings" for additional information regarding dip switches.
____ 8. When all connections are complete, replace cover and lock in place using the #6 ½ inch screws
provided. Plug in power supply.
Hi Steve,
Thank you for your response.  This was an existing V-9940 which was working with AudioCodes.  I think the issue is with the new analog gateway configuration.  I may have fixed the issue, but I wont know until I'm in the office tomorow..
Thanks again.
