07-07-2010 06:16 AM - edited 03-15-2019 11:35 PM
I have a Cluster of Cisco Unified Communicatio Manager Version 7.0.2.20000-5 (Publisher and Subscriber) .
I have Cisco Unified IP Phone 9951 and i want to add this.
Kindly Advise me how i can add this new cisco unified IP Phone 9951 in CUCM.
Best Regards
Jamil Hussain
Solved! Go to Solution.
07-11-2010 06:20 PM
Problem solve
First we downloaded device pack from:
and install according to intructions in:
http://www.cisco.com/web/software/282074299/33096/cmterm-devicepack-8_0_1_11002-1_readme.html
I need to reload CM to get phones working.
07-12-2010 06:04 AM
Jamil,
Your version of CCM ie CCM7.0 does not have a device pack for the 9900 series phones. You need the CCM 7.1upgrade DVD for this. After the upgrade you can then go to cco to dwonload the required patch. Please contact a skilled personel or a cisco partner if you do not have the skills to do this.
07-07-2010 06:20 AM
Hi Jamil,
You will need 7.1(3a)su1 at a minimum
Cisco Unified IP Phone 8900 and 9900 Series
Before using the Cisco Unified IP Phone with Cisco Unified Communications Manager, you must install the latest firmware on all Cisco Unified Communications Manager servers in the cluster.
Note You can install Cisco Unified Communications Manager 7.1(3) or 7.1(3a). After you install one of these releases, you must install Cisco Unified Communications Manager*** 7.1(3a)su1. ***
Cheers!
Rob
07-07-2010 06:20 AM
If 9951 is not available as a phone model on CUCM 7.0.2, you need to upgrade CUCM.
Michael
07-07-2010 06:26 AM
Yes 9951 is not available as a phone model on CUCM 7.0.2.
I need to upgrade CUCM or Device Package.
And if i need to upgrade first i need to install 7.1(3) and then 7.1(3a)su1.
Please reply
Best Regards
Jamil Hussain
07-07-2010 06:34 AM
Hi Jamil,
This is shown as a direct upgrade path from 7.0(2) to 7.1(3a)su1
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp194692
Cheers!
Rob
07-07-2010 09:56 AM
Hi Rob
I need to Purchase 7.1(3a)su1 or I can download it from software section from cisco.com.
And also one more thing i have a running environment well during upgrade it will affect my previous confugration ?
07-08-2010 09:07 PM
We have CM 8.0. when We tryed to add 9951 phone it also doesnt appear in phone list. what we need to put this phone in device list ?
Juan Carlos
07-10-2010 09:05 AM
Hi Ceron.
Could you please tell me the procedure for adding 9951 Phone in the device list.
How to add the phone in device List.
07-11-2010 06:20 PM
Problem solve
07-12-2010 12:16 AM
Does it supports same for Cisco unified Communication Manager Version 7.0.2.20000-5.
Jamil Hussain
07-12-2010 06:04 AM
Jamil,
07-12-2010 06:36 AM
Dear aokanlawon
Thanks for your reply.
I was just confirming about the device package if its supporting in CM Version 7.0.
Otherwise i can handle this task.
Jamil Hussain
07-16-2010 01:30 PM
Hi Good day to all
I have successfully upgraded CUCM 7.1(3)su1.
I have switched the version to new but received this error message after upgrading.Before i have uploaded the licence file for system and it was 2 one for PUBLISHER AND ONE FOR SUBSCRIBER.
Phone License Feature is ok but CCM Node License Status is Showing Missing
Licensing Warnings:
System is operating on insufficient licenses. Please upload additional license files.
I have attached the snapshot for licence report.
Please advise.
07-23-2010 06:17 AM
Hi all
I have successfully upgrade CUCM to 7.1(3a)Su1 From 7.0.
Now i am able to see the option for Cisco Unified IP Phone 9951 but when i added the phones i got error message on Phone " Unable To Connect".
I check the device default Configuration and found in the Load information of 9951 AND 9971 IS EMPTY.
I am not able to register my phone because of LOAD INFORAMTIN is empty.
Kindy assist me to sort out this issue.
Waiting for a favourable reply.
Regards,,,
