04-18-2019 01:32 PM
Is there a way to get a count of calls that were translated by CUCM via a translation pattern?
My voice gateway only keeps a few hours of data, so that's not too useful.
I use something like this to get quick call counts by extension:
run sql car select call_type,callingpartynumber, originalcalledpartynumber, datetimestamporigination, destDeviceName, duration from car:tbl_billing_data where originalcalledpartynumber like '583'
Thanks!!
Solved! Go to Solution.
04-21-2019 12:02 AM
I don't think there is any direct method. But you can try out below workaround I have tested the same in my lab. If you are not using MLPP feature then you can use the below method.
Just set the MLPP Precedence to something say FLASH then you can use CDR Report to find a number of calls translated via the TP.
Now you can go the the CDR>Search>By Call Precedence Level and Filter the calls using FLASH MLPP as below u will get the count.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
04-21-2019 12:02 AM
Haris
04-22-2019 06:08 AM
Hey, that's interesting.
If I have two such numbers to watch it looks like I should use different MLPP settings for each one, right?
I was considering some sort of double translation or an intermediate CTI route point, but this sounds easier.
