We will be switching to a cloud solution but want to continue to use our exisitng cisco phones. 8845 and 8945 series. The problem is, it looks like 3pcc was only supported on lower firmware versions.
Active Load ID: | sip8845_65.12-1-1-12 |
Inactive Load ID: | sip8845_65.12-0-1SR1-1 |
Download Status: | Failed |
Requested Load ID: | sip8845_65.11-2-3MSR1-1 |
Inactive Load Failure Reason | Internal Phone Error |
Is there anyway to ac
Solved! Go to Solution.
The process to go from Enterprise to 3PCC and viceversa is here
Depending on your contracts, there might be an associated cost.
That was the info i needed. Thanks
