04-01-2009 03:27 AM - edited 03-15-2019 05:13 PM
We don't have a CUE card in out 2811.
We have dual line 7941's.
Basically when i'm on a call, my Director sometimes calls me.
I can see on my display that he's calling.
He hears a ringing tone, not a busy tone.
Then the Director wonders why im ignoring him....
is there a way to impliment a busy tone?
I know about the call forward busy command but that isnt going to get me anywhere has I dont have CUE..
Help would be great!
Solved! Go to Solution.
04-01-2009 05:32 AM
Or can I just impliment the huntstop channel / no huntstop commands on my dn's and that will do the job?
Thats correct yes, you should just be able to add the "huntstop channel" command to the DN in question.
04-01-2009 05:18 AM
It sounds like you have call waiting enabled, basically when a second call comes in it is going to the second channel on the phone.
Have you configured the directory number as dual line?
To prevent the presentation of call waiting calls in a hunt group situation, you should use the command huntstop channel. This command can be used independently of, and in addition to, the plain huntstop command. The huntstop channel command prevents incoming calls from hunting on busy from the first virtual voice port channel to the second channel. It does not affect hunting between dial peers. It influences channel hunting only within the voice port. The huntstop channel command can be used in any dual-line ephone-dn. Its use is not restricted to ephone-hunt.
If so enable the "huntstop channel" command, this will stop calls hunting to second channel on a directory number.
ephone-dn 1 dual-line
ring external secondary
number 1000 secondary 0121*******
no-reg both
call-forward busy 9000
call-forward noan 9000 timeout 20
huntstop channel
no huntstop
However in the above example if the line is busy it will forward the call to voicemail, if you wish to just present a busy tone remove the call-forward busy statement.
04-01-2009 05:30 AM
Hi, I may well have call waiting configured then. they are configured up as dual-line yes.
Ok, I can remove call waiting - we don't really use it here. is that possibe?
04-01-2009 05:32 AM
04-01-2009 06:00 AM
Thats great thanks, works a treat!
04-02-2009 07:07 AM
ah back open...
thats put paid to my consultative transfers now.. I can only non consultative transfer now.
04-02-2009 07:29 AM
Could you post your ephone-dn config please, it sounds like the ephone-dn is now single line rather than dual line.
Dual line DN's are required for consultative transfers as it's it uses the second channel to place the call to another party.
04-02-2009 07:47 AM
bizarre.. two people complained that they tried to do consultative transfers and they just transferred the calls..
I made sure that the DN's were all dual line yesterday when i made the change (been there before)
All seems OK oddly enough..
04-02-2009 10:16 AM
Good news :)
